$1000 pc
I hope this is enough information help me with this.
  • Budget: 1000 USD. I could be given a build for 1500 because I am going to try an hit up stores on black friday to cut down on costs.
  • Region: USA
  • Retailer: Fry's, Best Buy, or Newegg.
  • Don't need a mouse or keyboard.
  • Will be used for gaming.
  • No overclocking.
  • Possibly water cooling in the future.
  • Do not need a OS.
Types of games and settings.
No point in getting watercooling really if you don't plan on overclocking. Also do you have any brand preferences?
AMD since it is a gaming rig no need to blow more money on a Intel chip, and everything thing else is whatever is good for a good price.
http://pcpartpicker.com/user/paul_sauce/saved/2o4E
you should be fine with this and have no problems getting to the requirements you mentioned.
Something like this is the most you will probably need for 1920x1080 but you have to get the cards soon before they run out of stock. Otherwise just spend like $600-$700.
http://pcpartpicker.com/p/1IGcL
I wouldnt get the old 8120, piledriver was a good update.
Its true though, for games you can just get a fx 6300 + mobo+ 8 gb ram for 200-250$, a 7950 for 200$ and stay around 500-600 total depending on what storage, psu and case you get and max out everything in 1080p.
you can get a lot of ssd storage for the rest of the budged, id expect there to be some great deals regarding that on black friday. You could also make a tiny gaming rig with a haswell i5 and a single rad water cooler in an elite 130.
Is there a any reason other then to keep it in the price range that you used a cheaper MoBo?
Total = $1,008, which includes your specified case. Mail-in rebates bring it down to $980. AMD FX-8350 with an Asus M5A99FX PRO R2.0 bundle for $265, from microcenter. Includes
In-Store Pickup Only Bundle: http://www.microcenter.com/site/products/amd_bundles.aspx
http://pcpartpicker.com/p/1JdJ1
FX-8350 with a Gigabyte 990FX mobo, Xigmatek Dark Knight for the CPU cooler, radeon 7950, a 120gb SSD, a SeaSonic 650W 80 Plus Gold PSU, all housed in the Fractal Design Arc Midi R2.
http://pcpartpicker.com/user/-MGX-JackChamp3G/saved/2tie
i make 2 options.
option1: http://pcpartpicker.com/p/1JgEK
option2: http://pcpartpicker.com/p/1JgDS
Diffrences between option 1 and 2 is the GPU, both are 7950´s but the Asus is not voltage locked so its more overclockable then the Gigabyte windforce, which is voltage locked. But Notice that the new AMD R9 series cards are gonne be released soon so i would recommend to wait, because the  R9-280X will be a rebrand 7970GHZ edition with some tweaks placed on a sweet $300 price spot. maybe its an interesting card to look at.
Let me know what you think.
Grtz Angel ☺
How about this? Nice case, SSD, quieter cooler than the stock AMD one. http://pcpartpicker.com/p/1Jh2O
