1000$ gaming system breakdown
http://pcpartpicker.com/p/20xFR
I went for a bias on the RAM, but I feel like I could have made do with 8 gigs and gone with a better graphics card. Thoughts? And before you ask, it is intended for minor Photoshop work and some fairly intensive gaming.
http://pcpartpicker.com/p/20xZ6 and fill in what ever else you need with what ever is cheapest when you go to buy. Just some tips, if you can go to microcenter they are the cheapest around for everything under the sun pc parts and if they arnt you can usually talk them into a price match, for buying ram, always get something that has life time warranty, for a PSU get something that is 80+ bronze the extra money you will usually spend to get something that is gold or higher isnt worth it in most cases for the increase in price, and for the last part a cooler..... that 8350 needs a real cooler dont go cheap.
http://pcpartpicker.com/p/20yb7
PSU- Made by Seasonic, just rebranded.  It's a good PSU.
RAM- 1600mhz RAM, won't make a difference compared to your 1866mhz ram in gaming.
GPU- GTX 770.  Better GPU.  More FPS.  Yay.
Are you referring to my personal system? The build at pcpartpicker.com doesn't include an 8350
well, his build does have an FX-8350 >.>
