$1000 Gaming PC [Aethyr Build: 1] - Revamp 3
I've been planning my $1000 Gaming PC build for a while, and been changing parts to and fro, and constantly checking which is better. For example, I originally had a 7950 from Sapphire as my GPU, but now I've seen an MSI 7970 at a better price. I'm pretty flexible with my build, and am willing to switch parts out. However, if you're going to suggest a part, I would love a reason why. Thanks in advance for any advice and suggestions you make.
[BIN'D] Link: http://pcpartpicker.com/p/1RjsU
[BIN'D] Revamped: http://pcpartpicker.com/p/1RuKg
[BIN'D] Revamp 2: http://pcpartpicker.com/p/1RMJT
Revamp 3: http://pcpartpicker.com/p/1RQnl
I'm a noob in the midst of compiling components for my first build.  But what I have heard many times around the interwebs is that liquid cooling is (1)unnecessary unless you plan to overclock the bollocks out of your cpu and (2) a pain in the ass.
http://pcpartpicker.com/p/1Rktw
Might be a little expensive, not sure.
That's custom watercooling; He has a closed loop cooler which are fairly straight forward, but the cheaper ones such as the one in this build are not as good as some of the air coolers for similar prices.
+1
If an ssd doesn't bother you go with this.
I'm not really picky about either having a fan or a water cooler for cooling the CPU. I was actually having mini-arguments between myself about which one to get. I know a Cooler Master Hyper 212 EVO is a really great CPU fan, but I also don't want a giant fan in the middle of my case, since it takes up space - I want some space in my CPU, which is why I chose to go for a water cooler instead of a fan. I'm more than likely going to upgrade on the water cooler. Any suggestions on that matter?
After reconsidering my parts, I have revamped the build to try. I'm still open for changes, but I believe this is a fair enough build, considering it's going to have at least the R9 280X (waiting to see the R9 290X).
I chose to put the H100i instead of a fan like the Noctua NH-D14 because I want a lot of space inside the case, and I feel that - despite the Noctua being a really good CPU cooler from what I hear - it would be the opposite of what I want. Everything is self-explanatory.
i made this:
option1: http://pcpartpicker.com/p/1RvpN
i think this will be a very nice setup its just a littlebit over budget, but its totaly worth it.
option2: http://pcpartpicker.com/p/1RvtD
Grtz Angel ☺
Don´t put the FX8350 on that Asrock 970 Extreme 4 board. thats realy a terrible combination. the 970 extreme 3/4 and also the 990FX extreme3, have only 4+1 powerphase and analog vrm. Those boards are just not made for a powerhungry highend 8core cpu.
If you wanne use a Asrock board for the FX8350, then the Asrock 990FX Extreme 4 with 8+2 powerphases and digi vrm or the Extreme 9 with 12+2 powerphases and digi vrm
But you would probably be cheaper if you buy the Asus M5A99FX pro R2.0
grtz Angel ☺
Really? Huh, I never knew that.
Originally, I wanted to go with an ASUS Sabertooth 990FX R2.0, but now I see the Sabertooth 990FX/GEN3 R2.0. That's about when I noticed the ASRock 970 Extreme 4 for a ridiculously cheap pricing. I know that cheaper isn't always better, but I heard good things about the motherboard - just never heard any good things about what processor it was paired with. I've decided to go with the Sabertooth 990FX/GEN3 R2.0 as my motherboard, which I'm sure will support the processor. I've heard good things about the Crosshair V Formula Z motherboard as well, so there was that option. It'll jump the price to around $1100 with either board, but I'm willing to pay that extra $100.
I want to have a case that has a side panel window so I can see the inside of my case (if I ever wanted to add some lights and/or liquid cooling), and I also want to have a water cooling system, instead of the after-market fan, so I don't have a giant block in the center of my case. Either fan or water cooling system will keep it cool, but I want to go for a more aesthetic look for the instead, which is where I think the water cooling system will be better for the aesthetics than a giant after-market fan.
But thank you for the information on the initial combination, I'll try and keep that in my head if I ever want to do future builds, where I get a 'less powerhungry' processor, I can match it with that build, or I'll use your suggestions on what to consider with the FX-8350.
Here's the build that I mentioned where I'll use the Sabertooth: http://pcpartpicker.com/p/1RQnl
Offcourse The Asus Sabertooth R2.0 or GEN3 is a realy great decission, with the FX8350. only the GEN3 is a bit expensive, but its because there is a PLX chip on it, that makes pci-e 3.0 availeble on the board. but for gaming the diffrence between pci-e 2.0 or 3.0 is not noticable. So i would personaly  go for the Sabertooth 990FX R2.0. but also a good and cheaper option for you could be the Asus M5A99FX pro R2.0.
I can understand that there's no noticeable difference for gaming, but I also plan on adding some extra stuff, like a high-end graphics card and a workstation graphics card, since I'm a musician and do some hobby graphic artwork. I'm not sure if that's what PCI-Express 3.0 is better for, but I'm going to assume that's negligible, like gaming. Granted, this may or may not happen, and if it were, it would happen a long time later, where better motherboards, GPUs, CPUs, etc. come out, where PCI-Express 3.0 would more than likely become standard in future motherboards (then it would grow into PCI-Express 4.0). I did plan on the former instead of the GEN3, and only went with GEN3 because it had PCI-Express 3.0 for future add-ons, and maybe the minor extra benefits, but I'm glad to know that my initial motherboard choice was the better one in this build.
