$1000 For 8 Gb of Ram
i....i don't even.... 3.1 Ghz ram! ADATA you crazy. (Or 3100 Mhz)
Also, Is it about time we move into making Ghz on ram the new standard?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211803
The funny thing is most systems wont even run that, not even Z77. If you were using Liquid Nitrogen or Helium you could probably get those to run on Z77 or Z87.
Next Step DDR4?
