http://pcpartpicker.com/p/ymMc
I am still deciding on the Motherboard, the one someone recommended has USB 3.0 but my Case front panels don't have USB 3. If one isn't possible with the same or better value then I will have to deal with it.
The HDD I am still deciding on, I had the Samsung Sinpoint previously but it is pretty expensive and I will probably only need 750 gb
The PSU is what I am worried about, the site says 350 Watts, but that doesn't seem right... I just chose this PSU because the guy on RazeTheWorld recommended it.
I am also wondering if the GPU can be replacable with a 7870 :D
IDK if I should go with a 7850 2GB or 7870 2GB :/
Also RAM, 1600 is fine right? It doesn't matter that much?
