so i have $1000 & i would like to build a new pc (and give the old one to my brother). i want to go to nvidia for the graphics card, intel for the cpu & one of corsairs cases , i dont mind about any of the other specs.
Any suggestions what to go with?
You could get quite a bit more gaming performance if you went with amd for the CPU and by performance I mean more money can be spent on the gpu so unless you are rendering there is no need for intel. You should also consider the Thor v2 from Rosewill since it is pretty much a god tier case for so cheap (with stock fans compared to a stock corsair 900d it wipes it out.)
i made this: http://pcpartpicker.com/p/1F9RH
i think this all contains what you want, i would personaly recommend to with a Radeon 7950 card instead of a GTX760, because the Radeon is a better performing GPU, but if you prefer Nvidia and intel, just go for it.
AMD option with GTX760: http://pcpartpicker.com/p/1F9XD
Intel option with 7950: http://pcpartpicker.com/p/1F9Zo
AMD option with 7950: http://pcpartpicker.com/p/1Fa1a
i think all thease builds will fit your needs, the AMD with Radeon 7950 will be the best bang for buck rig.
grtz Angel ☺
i may go with amd, i just thought intel works better with an nvidia card :3
