http://pcpartpicker.com/p/1hsVE
What do you think?
What do you think?
link is broken and is showing me my build.
The Link does not work!
The link posted links you back to your own build and configuration on the site. if you have an account there.
Hot Steam- When you have the build list there should be a spot that says "Permalink" copy and paste that.
Use the "EDIT" option at the top of your post to edit it instead of commenting a new one in.
Fixed
Is the monitor inclued in the $1000 budget? if so this is how i would do it http://pcpartpicker.com/p/1hvI5 this is also below your buget so you could updgrade to a better ram or a case that you think looks better
