$100 keyboard and mouse combo
For the mouse, i dont require many buttons and rather something along the lines of half palm grip/claw grip.
On new egg i found the microsolf sidewinder x4 and its gotten pretty good reviews but idk what mouse i should go for, any help would be greatly appreciated...that is all
http://www.newegg.com/Product/Product.aspx?Item=N82E16823129007
http://www.newegg.com/Product/Product.aspx?Item=N82E16826153056
It's a little bit more than $100 but you can't get a better deal.
is there another mouse you could recommend? maybe something more ergonomic? im right handed btw
Well, I usually recommend Logitech G400 but it's mostly for palm grip unless you have very large hands. (I fingertip grip it which usually causes people to be surprised). Abyssus is the cheapest mouse with a precise sensor and it should be claw-grip friendly.
how do you feel about the g300?
I didn't try it in real life but:
Sensor is not in the center.
Shape doesn't look ergonomic.
It's probably ok but I wouldn't gamble on it.
id hate to be a bother but does the abyssus have a changeable led or is itlimited to blue?
Nope, you can't change the color.
I have the logitech g9x and I love it.  I found it on sale for 40$,
 Here's one for 43$
http://compare.ebay.com/like/230965255970?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
For under $100 I would suggest:
Logitech G105 keyboard. It isn't mechanical but it definitely does live long and performs quite well in typing.
Microsoft Wireless 3500 mouse. It lasts very long and it's great for the claw gamer who only wants to spend little on a mouse. I personally don't look at gaming mice because I perform the same with this mouse then with any other. It has a decent sensitivity too.
PRICE
Logitech G105 $50
Microsoft Wireless 3500 $30
Most likely ill be getting the cooler master keyboard, thank you Dissentient
but i dont want a wireless mouse, i prefer wired
