$100-400 htpc
So, I'm looking to save money and build a decent htpc. I have a exturnal network harddrive laying around so I was think just putting all my movies/tvshows to that and just streaming it to my htpc. If youguys can build me one for as little as you can that would be awesome.
$270
http://pcpartpicker.com/p/1aqwa
I put this together. I built it around cost, but I didnt want to sacrifice quality parts. You shouldnt have any issues with this processor if you were multitaskng, streaming, and etc. The processor is also a light 65 watts for saving on electric bill. I put an SSD because since you will be streaming from another machine, you dont need storage, and this will allow you to boot up and shutdown the system in about 8 seconds. So no waiting and no HDD slow downs. I chose this ram because it is lower voltage and will save you some money in the long run. Also 4 GB is the sweet spot for streaming larger files. You might run into buffering problems steaming HDD on 2 gb.
The case is a little too big, but for the price, it is good for airflow to keep everything cool and quiet while you are watching movies.
If you want something all black then I would say this for the same price.
http://pcpartpicker.com/part/silverstone-case-ps08b
For a mouse and Keyboard try this:
http://www.newegg.com/Product/Product.aspx?Item=9SIA24P0SM4493
http://pcpartpicker.com/p/1aqZQ
CPU: AMD A8-5600K 3.6GHz Quad-Core Processor ($98.24 @ Amazon)
Motherboard: ASRock FM2A75M-ITX R2.0 Mini ITX FM2 Motherboard ($91.97 @ Newegg)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory ($63.00 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($64.98 @ Outlet PC)
Case: Cooler Master Elite 120 Advanced (Black) Mini ITX Tower Case ($39.99 @ Amazon)
Power Supply: Antec EarthWatts Green 380W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($47.98 @ Newegg)
Total: $406.16
