So can I get a second USB receiver for my Logitech Headset and connect it onto my WS and use only this single headset ?
Currently I have a wireless Logitech on my gaming rig that I use from time to time and an older Wired USB headset on my WS which I use with my softphone, Ring Central.
Any thoughts or recommendations ?
I dont think this will work but i am not sure. (85%) Do yo have the specific headset model?
@mutation666
Yeah, it’s the Logitech Pro X Wireless.
I heard recently about the Logitech adapters with the orange symbol on it (Unifying adapters?) that you can reprogram to work with different keyboards and mice using some sort of program. A quick search shows people pairing devices using the Lightspeed dongles to replacements using a Logitech Lightspeed utility. I also saw something mentioning that it will pop up under Bluetooth. I don’t know if you would have to spend a minute pairing each time you switch or if it will just work, but it’s probably worth a shot getting a second adapter.
Thanks for the feedback @KleerKut
