Hello folks! Im a new ubuntu user. On windows 10 i have setup one monitor plugged on gpu and one on the motherboard (i-gpu). Working as extended displays. im trying to replicate this on ubuntu but no luck. i can only manage to get only one at a time to work. but not both together. Do we have any solution? Im noob btw plz halp /
To have a robust and easy solution use adapters from the outputs of the graphics card to vga. Your current setup might be configurable in ubuntu but it is not worth the trouble of setting it up as the adapter solution is way simpler and more robust.
As your GTX 960 has DVI outputs you can use two of such inexpensive adapter from DVI to VGA.
If you have only 1 DVI output there are many inexpensive adapters from HDMI and DP to VGA on which you can attach the other monitor. (see post #4 for example).
Guys thanks for the replies. but you all sugested to buy adapters. my hardware is capable of doing the 2 monitor setup on win10. i dont understand why is it so dificult to replicate it on ubuntu. as i said before this is my setup on win10 -----> http://imgur.com/ayJFBUa <-----
