1 headset, two gaming platform
I have a turtle beach X21 headset which I use for my xbox 360 and my pc. It requires the USb, audio, and microphone ports to be plugged in on both my console and PC to work, I was wondering if there is a piece of hardware I could use so I do not need to keepy reaching in back of my pc to unhook my headset. (I need to keep a clean desk).
A KVM might work such as the one posted below. It has a button you press to switch between which part of the KVM to use, so you could split it in two. You may need to research a bit more to see if this thing would actually work but it's a start. http://www.amazon.com/IOGEAR-Cable-Switch-Audio-GCS72U/dp/B002K0TU2C/ref=sr_1_1?ie=UTF8&qid=1357851520&sr=8-1&keywords=KVM+mic
Thank you good  sir
