This is going to be a sand rail computer case, I've always wanted to make a sand rail so im going to start small lol
I've never made something like this before so starting out was real frustrating my bro was showing me how to use solid works and though that was cool i didn't know how to build what i wanted. I decided to make a mock up and what better way then using some cardboard and duct tape. once i got that somewhat laid out I took some welding rod,brake line bender and bailing wire to make a prototype of what i was looking for. the final will most likely be 1/4 tubing but this was a realy cheap way for me to get my head around what i wanted.
Just starting out
Basic layout
starting to bend some rods
side view
Sides and risers bent/cut
welding the risers on ( my bro's the welder)
Alright both sides on time to get bending
below are what i have so far just different angles
Next to work on front/rear suspension and various support areas, still not exactly sure where the rads are going to go. i need the a arms setup up front so i can either bring the bottom nose in or the upper nose out to give it more of a rake look. the body isn't square but this is just a mock up so i can see what i need to modify so every thing fits. contents in this build will be current pc
psu : evga 1300 g2
gpu r9 290 x 2
cpu: 8320fx
mobo: asus maximus v formula z 990fx
storage is undecided, the cpu,gpus and vcore will be water blocked
If you have suggestions or words of advice by all means enlighten me.
