Hello,
I brought this KVM like a month ago. I connected to it a desktop, mac(m1).
As peripherals:
Mouse (HID): logitech G502 lightning wireless
Keyboard: RII 100
Microphone (HID): HyperX QuadCast
The problem that I have is when switching between PC/mac occasionally the KVM gets stuck. While stuck, the display is working fine but one or more peripherals might not be working and I can not switch to the other computer using the physical buttons on the KVM or hotkeys. I should mention that if it gets stuck and you attempt to switch between the 2 PC, if you press the button corresponding to the other PC that indicator will have the red light, but as soon as you release the button, the light goes back to the initial indicator(the one which got stuck on).
The last time it got stuck, the mouse and the keyboard were working fine, but the microphone was not working. I tried to unplug the microphone and plug it again but it didn’t make any change.
The only way to solve the issue is to remove the power cable. I tried to remove the cable going from KVM to PC but that didn’t help either.
