1.2 DP KVM and Dell U2725QE
I recently got a Dell U2725QE monitor and I’m having lots of problems using it with the Level1Techs 1.2 DP KVM (SQ2625416). The monitor is detected by the OS (macOS and Linux), but most of the time the screen is blank. If I toggle the KVM inputs and reconnect cables enough times I usually can get it to display the desktop. Once it’s working it remains working, but swapping inputs is likely to blank the screen again.
I also have the DP repeater, which usually sits between my MacBook Pro and the KVM. I’ve pulled that out of the loop with no improvement. I also moved it between the KVM and the monitor to see if I could keep the monitor in a good state while toggling KVM inputs, but no luck there either. I have two of the DP repeaters, with the same results, so I’ve ruled out the likelihood of a broken repeater.
Potentially related, macOS will not allow me to change the refresh rate over 30 Hz when connecting to the monitor through the KVM. I also tried going MBP→Repeater→monitor (i.e., pulling the KVM out of the loop) and I still can’t get it over 30 Hz. I assume there’s something odd with the monitor since the LG 4K I replaced ran 4K@60 no problem. I’d accept running at a lower resolution if it’d get the screen working, but I haven’t had luck doing that either.
Has anyone run into anything similar? For now, I’ve run the DP cables from my desktop and laptop to the back of the monitor and manually swap them when I want to change input source. That’s getting tedious, as you might imagine. I’d appreciate any help or explanation of what may be wrong.
