-$1,000- Gaming Build | First Build
Ok this is the build that I have made. I already have everything like monitor, keyboard etc.
I am looking for the best bang for my money. I will be playing games like BF3/BF4, Metro 2033, Star Craft 2, Crysis 3. I will be overclocking and will probably get a second graphics card at some point. Some things that I will require are a modular power supply, probably a quiet case like the Fractal Design R4 and Windows 7. Budget is $1000 and will be getting the parts in a few weeks.
http://pcpartpicker.com/p/SZOp
Looks good although for the best bang for buck I'd look at this card http://pcpartpicker.com/part/sapphire-video-card-111992020g
7870 > 1280 shaders, Pitcairn based GPU
7870XT > 1536 shaders, Tahiti based GPU.
I have changed the build slitly and it does come out a $100 more but I think that it is worth it.
AMD FX-8350 4.0GHz 8-Core Processor ($179.99 @ Microcenter)
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Outlet PC)
Asus SABERTOOTH 990FX/GEN3 R2.0 ATX AM3+ Motherboard ($199.99 @ Newegg)
Kingston Beast 8GB (2 x 4GB) DDR3-1600 Memory ($76.50 @ TigerDirect)
Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($84.98 @ Outlet PC)
EVGA GeForce GTX 760 2GB Video Card ($259.99 @ NCIX US)
Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case ($99.99 @ Amazon)
SeaSonic M12II 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($99.99 @ Newegg)
Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Total: $1121.39
I think this build will play any modern game at max settings @ 1080p or higher resolution without any problem.
http://pcpartpicker.com/p/1cKWU
Hope you like this build! EnJoY :)
I'd stay away from AsRock's 970 Extreme 4.  Several people said that (and Extreme 3) are not great boards for overclocking.
M5a99FX Pro r2.0 [+1]
Ok everyone this is what I am deciding to go with. I know it is over budget but it will do. Ordering the parts next week!
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($179.99 @ Microcenter)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler ($49.99 @ NCIX US)
Motherboard: Asus SABERTOOTH 990FX/GEN3 R2.0 ATX AM3+ Motherboard ($199.99 @ Newegg)
Memory: Kingston T1 Black Series 8GB (2 x 4GB) DDR3-1866 Memory ($59.09 @ Amazon)
Storage: Kingston HyperX 3K 120GB 2.5" Solid State Disk ($114.99 @ Microcenter)
Video Card: EVGA GeForce GTX 760 2GB Video Card ($259.99 @ Amazon)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case ($99.99 @ Amazon)
Power Supply: SeaSonic M12II 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($122.98 @ Newegg)
Operating System: Microsoft Windows 8 (OEM) (64-bit) ($87.98 @ Outlet PC)
Total: $1174.99
http://pcpartpicker.com/p/1dHtc
