1,000 dollars for a full fledged Pc (including monitor(s) and peripherals)
Okay i need your guys help, i need to build a pc with a bit of a strict budget of 1,000 dollars.
I'll do medium to a bit of heavy gaming with some light ideo editing. I I have nothing to start with, no monitors not even a mouse to use no spare parts (thats a lie but lets just assume)
Imagine only having 1000 dollars to buy everything need for a computer before going on a stranded island with no way of buying anything else in the future what you take with you is what youlll have forever while staying in that island with magical wifi and power (yes wifi please)
In the pc i need all the basics, and with the 1000 dollars make it as fancy as possible by adding SSD's fans and such
i dont want to seem like im just coming in and asking you to build a comp from scratch,
i was already planning on getting an intel i3 4-8 gigs of RAM with a GTX 650 1G windows 7 or 8 not sure.
I beg someone to please help me out D: i wanna impress my friends cause they dont believe i can build a comp (never built one) but i've read and watched countless tutorials on how to build pc's now i just need to order the parts.
(Edit: i was gifted 4 G of 1600 ddr3  RAM yay)
Updated partlist: http://pcpartpicker.com/user/Joseph000555/saved/1thK
 http://bit.ly/ZAqoNf ive also picked a new full tower case, its expensive but just for the lols it looks awesome (125$)
list thanks for all the help and suggestions everyone!!!
http://pcpartpicker.com/p/QGc2
best i could do no ssd but  has enough storage space to last you a while.
It's.. It's Beautiful
might decrease the hard drive space to 1 TB and lower wattage of the power supply to include windows on there but thanks so much :D
http://pcpartpicker.com/p/QX6l
Check Mudrii's build, that's the way to go, the 7850 will run way better than the GTX 650.
Good luck, if you have any doubts on the building process, just come over the forums and ask, we will be happy to help you, and we won't tell your friends we did :)
http://pcpartpicker.com/p/R6Hy
Thanks guys but im still a bit tight because i need an OS, any suggestions on what to cut down to have room for it?
Use the pirated one, I explained how in some of the threads in this subforum
Here is something that should cover windows 7:
http://teksyndicate.com/forum/windows/windows-7-torrent/136112
If you want windows 8, just go to kickasstorrents.com and search for windows 64 bit, and a keyactivator. I think you can follow the instructions from imgburn. (in the post)
If you choose win8, you will probably want to get rid of the trash, so:
http://teksyndicate.com/videos/de-suck-windows-8-best-windows-8-start-menu-start8-vs-start-back
erm... windows 8 64 bit...
I've got an IPS234 LG monitory. 1080p IPS 5msec response time cheap ass monitor. 140€ here=182$ or:
http://pcpartpicker.com/part/lg-monitor-ips234vpn
Guys i Need to know the difference between the chosen CPU's in this build
http://pcpartpicker.com/user/Joseph000555/saved/1thK which has a AMD 6 core FX-6300
or a i3 Intel dual core lga 1155
i want one that one last me much longer, i dont know if thats relevant or not, but i dont mind performance i want durability so which one should i pick?
nobody can see the future. The AMD BEATS IT. For upgradeability I don't know. Maybe Haswell could be a kick from AMD for new motherboards, but maybe you will be able to upgrade. AMD is known for upgradeability. You won't regret buying the 6-core Vishera. I don't like benchmarks, but I think this is showing the truth:
http://www.cpubenchmark.net/high_end_cpus.html
 This benchmarks show, that a 6-core Vishera is nearly the same as a 3570k. Now imagine if games use more cores, what kind of advantage you will get. Performancewise it would be a mistake choosing the i3, a BIG mistake. I have that CPU, it's great! If amd can offer that upgradeability, they will. 2 intel cores can't beat that! I could've choosen the 3570k, but I like the price more. I wouldn't do it for a crappy i3 that is more likely the performace of a laptop, and not with such a budget like yours.
Kind regards
+1 on the FX6300, it's the most balanced value-for-money offering in the AMD range at the moment. The FX8350 is faster but also emits a lot more heat, so you'll have to invest in cooling before overclocking, and it draws a lot more power, so you'll need a more expensive motherboard to overclock it.
An FX6300 on the other hand is compatible with quality well-featured budget motherboards like the Gigabyte GA-970A-DS3, which can overclock the FX6300 without problem and has a lot of USB3 ports and SATAIII onboard and a decent audio subsystem, while at the same time belonging to the Ultra Durable range, which features high quality components and moisture/overvoltage-protection. This board has a simple VRM, but it's digital PWM based and powerful enough for the 95 W TDP FX6300. If you belong to those that don't want to spend more on the motherboard than on the processor (I'm certainly one of those myself), maybe such a simple board is enough for you, and you can save some money for faster RAM, or a bigger SSD, or even a great gaming mouse or a better monitor.
The FX6300 is a potent processor, in computing experience comparable to a Core i5-3570k.
There's still a lot of Phenom X6 PC's out there with competitive gamers, which was the previous iteration of the AMD six-core, and they don't plan on updating because their systems are doing just fine, so if you get the newer iteration, you can't go wrong for years of gaming pleasure.
As to the graphics card, in a 1000 USD system, I would go for an AMD 7870XT card, it has the 7970 Tahiti chip, it's very overclockable, the driver are good, the price is right, and it's a good performance match for the FX6300. Adobe is developing OpenCL acceleration for AMD cards in Photoshop, Premiere and After Effects, so in the near future, it is to be expected that an nVidia GPU is not an advantage for Adobe rendering acceleration anymore. And if you're not Adobe-dependant and use OpenShot or KDEnlive in GNU/Linux, you'll have to wait a little longer, but the same will happen there.
In a 1000 USD system, I would not invest in a sound card or a mechanical keyboard, but I would invest in a laser gaming mouse because getting the right gaming mouse for you makes a lot of difference.
I would also get the Arctic Cooling Freezer A30 before the Cooler Master Hyper 212 Evo, not that you need the massive 320W of cooling performance of the A30, but it's very easy to clean and the radiator volume is bigger and although it's also a direct touch heatpipe thing, it's a bit more solid and beefy, and the fan shroud on it stops a bit more annoying noise when the fan ramps up on a hot gaming day. It's about the same price, and comes with arctic silver mx4 TIM in the box (parallel fine line method should be used for this type of cooler to avoid hot spots on the processor heat spreader because of TIM buildup between the heatpipes, that will cause core temp variations that may reduce performance and lifespan).
I also prefer Kingston Memory over Corsair Vengeance, just because in my personal experience, I've had a bit more RMA with the corsair vengeance and the kingston works at more different speeds, so is a bit more flexible. Kingston HyperX Blue 1866 is not more expensive, and stays at 1.5V over the range, but can handle overvoltage when overclocking, and it has quite a bit of headroom for that. It does draw a bit more amps of electrical power at 1.5V at a certain clockspeed where other memory runs at 1.65V (Ohm's Law).
Most modern routers have gigabit-ethernet ports, so if you can, go wired instead of wireless. Most motherboards have good gigabit-ethernet NIC's built in.
When you buy essential hardware for a PC to build yourself, you can get an OEM-version of Windows, because you're a system integrator, or you've bought it together with a system, either way you want to look at it, you're within the EULA for an OEM-version.
Thanks! Will Definetly be getting it then!
okay, quite a read, but heres my reply:
Concerning the sound card, i have a a good headset designed for gaming (Astro A40's), i currently use it on my xbox. The thing i dont know is, if the motherboard im getting will be able to support it, hence the sound card :p if you could give me some insight on that id reqally appreciate it.
for the graphics card, i really like the current price for the one i have, i dont need it to run crysis on ultra any time soon, I prefer a well balanced pc with as many features and nothing left out (Future upgrades and updates will be a pain)
I unfortunately cant go wired, i know most motherboards have giagbit ethernet, but i only have wifi with a good signal
As for the mouse, i saw a lazer version of the one im getting for about the same price, so ill make sure to pick that one,
Also the mechanical keyboard isnt completely neccassary i fell in love with the razer when i first tried it, and disagree with me but i really like the feedback noise
I would prefer not to overclock much, i wont be running photoshop or other cpu dependant programs, maybe some light video editing, just for simple videos, but nothing fancy
If you say theres a better cpu cooler for the same price id happily take it
i didnt know until recently torrenting windows 7 was so easy and free
If You can take my link http://pcpartpicker.com/user/Joseph000555/saved/1thK
(keep the mouse, keyboard, sound card,) and  edit it to your liking within the same price range I would greatly appreciate to see your opinion on the parts :D
then get the gigabyte GA-970A-DS3. It has 2 pcie 16x slots. Which is enough in this case for you. Now get an HD 7870 with that saved money, which is better. You can crossfire it in the future. (not possible with 650ti..). Particulary for gaming, I would say skimp on the keyboard, and get something that costs half of that price, or just a nice looking, good working keyboard. And with that money you can get a 750 watt PSU!=
http://pcpartpicker.com/part/seasonic-power-supply-ss750am
And if you buy just a "beautifull, and good working" keyboard for 15-20 bucks. You could get an IPS-Panel Monitor.
LG IPS 234
the computer says its going to run on on less than 400 w, isnt 750 a bit overkill? i got a corsair 600 i think its enough, i dont plan on killing the powerbill :P, oh and could you link me to the gpu? not rally sure which one youre talking about
Updated partlist:http://pcpartpicker.com/user/Joseph000555/saved/1thK
If you have any suggestions to make it better and/or cheaper, or just want to pitch in an idea feel free!
